Activity › Forums › Apple Final Cut Pro Legacy › what takes longer – Grading in FCP or Color
Posted by Max Huggett on July 26, 2009 at 9:51 amHi guys
I have a 7 hour instructional DVD series, that i am editing, from a 3 camera shoot that i did. The vision, has the color blue in the BG and on the floor, and i would like to boost/saturate it a little.
I have done a test to see if i could isolate the single color, and using the 3 way cc, i was able to. I have applied it to about 15 shots (4 mins), which also have some other form of cc to match the color of each camera. The render on an 8 core Mac pro, is about 8mins. Thats quite along time and when i have 7 hours or so, that can take a while.
Is it quicker to do these color adjustments/grade in color?
Thanking you.
MaxChris Davis replied 17 years, 1 month ago 6 Members · 14 Replies -
Hector Berrebi
July 26, 2009 at 10:19 amit sounds long… do you have anything other than 3-way on your shots?
does your timeline matches your media’s settings?
is it a gray render line without the 3 way filter?
it should be a faster render
the job you described seems quite technical and repetitive, i believe you will be better off staying in fcp.
color could probably do it, maybe even better, but you won’t save time,
and you would be using a Ferrari to drive 2 miles to work… 🙂color is much more than a technical fix-it tool… its a story telling enhancer designed to allow great freedom in complex and simple color manipulation. it has a language and a workflow of its own, which has a learning curve… etc’ etc’ you got my point..
peace
Hector Berrebi
Schibber Group
prePost Consulting -
Max Huggett
July 26, 2009 at 11:33 amHi Hector
Yes…it is repetitive and should be quite easy to grade, but my cameras did not match each other, and at times, the exposure goes a little crazy, so i am trying to match shot to shot before i attempt a saturation on a color.
I am working in a ProRes project with settings of 1440×1080, with lower thirds also frequently popping up.
Before i apply effects, my timeline is green. With the lower thirds over it, it is periodically red. A simple 3 way cc does not affect the green line, however it is the other cc effects that slow it down.
I am also finding that over the 10 frames, that my lower thirds fade out, somehow, it also affects the cc on the vision layer below it. So there is a color shift for that 10 frames. When i delete the dissolve and reapply, re-render, it fixes it, but i don’t really want to do be doing that for the 7 hour project.
I might just turn off the lower thirds and work with the master layer and see how that goes.
Cheers
m. -
Hector Berrebi
July 26, 2009 at 11:41 amwhat was it shot on?
what other filters are you using?
Hector Berrebi
Schibber Group
Max Huggett
July 26, 2009 at 11:42 amupon further inspection, i can only apply 1 3way cc to the layer before, the red render bar comes up on the second application of it.
Max Huggett
July 26, 2009 at 11:43 amit was shot on HDV and ingested at proRes 1440 x 1080. No other filters are applied.
The effect is being applied to a multicam layer if that helps? And all other layers above, have been turned off.
m. -
Walter Biscardi
July 26, 2009 at 11:45 am[Max Huggett] ”
“Do you know how to use Color? That’s the key right there. If you don’t know the app yet, then it will take longer.
Myself, I would take the project into Color, but then I know the app.
Walter Biscardi, Jr.
Editor, Colorist, Director, Writer, Consultant, Author.
Credits include multiple Emmy, Telly, Aurora and Peabody Awards.
Biscardi Creative MediaCreative Cow Forum Host:
Apple Final Cut Pro, Apple Motion, Apple Color, AJA Kona, Business & Marketing, Maxx Digital. -
Max Huggett
July 26, 2009 at 11:54 amHi Walter.
i know how to grade with After Effects really well. and i was just playing around with color and it did seem easy to use, especially using the the applied Grade settings which i made and copied to each of the 3 subsequent shots.
But even in FCP, i am doing the same thing….. appyling a few filters then copying and pasting to each shot.
I guess i was hoping for it to be realtime and no rendering as i am going to run low on disk space.
M. -
Walter Biscardi
July 26, 2009 at 12:11 pm[Max Huggett] “I guess i was hoping for it to be realtime and no rendering as i am going to run low on disk space. “
None of the color filtering is realtime whether it’s FCP or Color.
Disc management is one of the things that most people have issues with because they always figure enough space to capture media, but nobody thinks about the render space. This is why we run 40TB of media storage in my shop though we only have maybe 10TB full at any given time. We never have to think about “do we have enough space to do this job?”
Hector Berrebi
July 26, 2009 at 2:25 pm“upon further inspection, i can only apply 1 3way cc to the layer before, the red render bar comes up on the second application of it.”
then i believe there is something wrong with your settings…
make sure the timeline is set exactly like your source clipsor maybe something moved and you didn’t notice?
any motion tab changes?
did you grade after collapsing your multiclip?
Hector Berrebi
Schibber Group
David Roth weiss
July 26, 2009 at 3:21 pm[Max Huggett] “I guess i was hoping for it to be realtime and no rendering as i am going to run low on disk space. “
Disk space is important, but more important, exactly what type of media drives or RAID are you running? The greater the throughput from a hard drive sub-system, the more realtime performance you will get, and if you skimp in that one area, the editing process simply becomes slower than it would if you didn’t skimp. The laws of nature do apply…
And, as Walter mentioned, grading in Color will not save time if you don’t know the app. If you do know Color it can be faster because you have much greater control than with the 3-Way CC. However, it’s not always speedier, because whenever you gain additional control, your desire to exercise that control can increase exponentially.
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
