Activity › Forums › VEGAS Pro › What size/aspect ratio’s should photos be for 16×9 480p widescreen montage?
  • What size/aspect ratio’s should photos be for 16×9 480p widescreen montage?
    Posted by Matt Long on April 4, 2011 at 10:21 am
    Hi All,
    I’ve taken pictures using a Canon 5DMarkII (5614×3744) RAW and I need to create a DVD NTSC 480p wide-screen photo montage using Sony Vegas Pro 10.
    1. What size should my images be set to in Photo-shop, and which format (jpg,png) should I use?
    2. What should the aspect ratio be set to in Vegas on the project level?
    3. What should the aspect ratio be set to on the time-line level under the media tab, when you click on properties on the image/time-line?
    Thanks.
    John Rofrano replied 15 years, 5 months ago 2 Members · 3 Replies
  • John Rofrano
    April 4, 2011 at 2:05 pm
    [Matt Long] “1. What size should my images be set to in Photo-shop, and which format (jpg,png) should I use? “
    NTSC Widescreen is 873 x 480 in square pixels. If you are not going to add movement to the images by zooming in and panning, you should make your images 873 x 480 in Photoshop. If you want to leave room to pan and zoom, keep them 2x that or 1746 x 960. I like to use JPG but others use PNG. It’s up to you. Both work equally as well.
    [Matt Long] “2. What should the aspect ratio be set to in Vegas on the project level?”
    The Pixel Aspect Ratio (PAR) should be: 1.2121 (NTSC DV Widescreen). I would just use the NTSC DV 24p Widescreen (720×480, 23.976 fps) project template and don’t change anything.
    [Matt Long] “3. What should the aspect ratio be set to on the time-line level under the media tab, when you click on properties on the image/time-line?”
    Since these are still images, the pixel aspect ratio should be 1.000 for the media (square pixels). Vegas will set this correctly by default.
    I would also render to 24p since this is the only progressive format allowed on an NTSC DVD.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Matt Long
    April 11, 2011 at 2:32 pm
    I want to add a video from my Canon 5dMarkII, which I believe is 30fps. I can’t add two different frame rates on the same disk/DVD correct?
  • John Rofrano
    April 11, 2011 at 3:00 pm
    [Matt Long] “I can’t add two different frame rates on the same disk/DVD correct?”
    Sure you can. A lot of Hollywood DVD’s have the featured movie in 24p because it was shot on film but the “special features” might be 30fps (29.970) because a lot of behind the scenes footage is shot on video. There is no problem having both on the same DVD.
    ~jr
