Activity Forums Blackmagic Design what should my BM capture settings be for my online with my declick HD?
  • what should my BM capture settings be for my online with my declick HD?
    Posted by Jeremiah Black on October 26, 2006 at 7:33 pm
    I have a tv show shot at 23.98 fps with the Varicam. I digitized the offline via firewire, and now it’s time to online the footage capturing via SDI. But can someone tell me what blackmagic preset I should select for the recapture? “Blackmagic 720p 23.98 – 8 bit?”. Will this still remove the flagged frames? I know what capturing with the DVCPROHD codec over firewire removes the flagged frames and gives me a 23.98 fps file. But will this still happen when capturing uncompressed over SDI via BM decklinkHD??
    thanks,
    – jeremiah black
    Jeremiah Black replied 19 years, 9 months ago 2 Members · 4 Replies
  • Andrew Mcleod
    October 27, 2006 at 1:44 am
    Hi Jeremiah
    The Varicam 720 23.98 preset will produce 8bit Uncompressed media @ 23.98fps.
    Depending on whether your camera was set to 59.94hz or 60hz will depend whether it will capture correctly.
    If unsure – perform a quick test using the 720 59.94hz and 60hz and see which format is captured.
    Decklink 5.7 includes Varicam support with Uncompressed 8bit and MJPEG.
    Let me know how you progress.
  • Jeremiah Black
    October 27, 2006 at 5:38 am
    “The Varicam 720 23.98 preset will produce 8bit Uncompressed media @ 23.98fps. ”
    Awesome, thanks. Just wanted to be sure I chose the right one so that the flagged frames were removed.
    “Depending on whether your camera was set to 59.94hz or 60hz will depend whether it will capture correctly. ”
    I believe it was shot at 59.94. Is this right?
    “If unsure – perform a quick test using the 720 59.94hz and 60hz and see which format is captured. ”
    please explain that agian. how do I do the test?
    “Decklink 5.7 includes Varicam support with Uncompressed 8bit and MJPEG.”
    OKay, I’ll install 5.7.2 right now! thanks.
  • Jeremiah Black
    October 27, 2006 at 5:53 am
    One more question:
    If I have slo mo that’s 59.94, how do I capture that uncompressed 8 bit SDI? I assume there’s no way to slow it it’s 23.98 upon capture, is there?
    thanks,
    – JB
  • Jeremiah Black
    October 27, 2006 at 6:30 am
    “Decklink 5.7 includes Varicam support with Uncompressed 8bit and MJPEG. ”
    I installed the 5.7 drivers and found that they ruined the realtime dvcprohd downconvert. Was all studdery and jumpy. For the online I’ll have an HD monitor, but for the next week I’m using an SD monitor and relying on BM’s downconvert. And like I said, the ugrade the 5.7.2 drivers killed it.
    Had to reinstall 5.6.2 drivers. Downconvert back to normal now. But I noticed that the “varicam” setings are all the same in the easy setups in the 5.6.2 as in 5.7.2. So it should still work, yes?
    Don’t know why it didn’t work. Maybe cause I’m still in fcp 5.0.4 and not 5.1?
