Activity Forums Apple Final Cut Pro Legacy What should i buy? An internal hard or External Hard drive? or does it not matter?
  • What should i buy? An internal hard or External Hard drive? or does it not matter?
    Posted by Milton Hockman on September 27, 2006 at 10:25 pm
    I am in the market for buying more HD space. i am wondering if there is a difference in buying an internal drive or an external drive when operating FCP or AE.
    does it matter which i get? i want to get a 300 GB drive to work off of.
    also, if internal is preferred, does anyone nkow the specs that i need to look for when buying an internal drive? like SATA or IDE or whatever? i plan on getting one off of newegg.com
    thanks
    Milton Hockman replied 19 years, 11 months ago 3 Members · 3 Replies
  • David Roth weiss
    September 28, 2006 at 2:20 am
    There are 2 SATA drive bays in your G5. If you only have a system drive now you can easliy install another SATA drive in the second bay.
    The best drive for your purpose is in fact available from Newegg at https://www.newegg.com/Product/Product.asp?Item=N82E16822144032. Maxline is Maxtor’s enterprise level drive, meaning that it carries a 5-year warranty. These are great drives — I have many of them myself.
    DRW
  • Walter Biscardi
    September 28, 2006 at 11:23 am
    I’ve never been a fan of internal storage, especially when you’re only talking 300GB because it’s easier to share storage around when it’s an external drive. If you work with another person or need to take your project to another system, you simply take the hard drive with you.
    Also, I can very easily swap off or daisy chain drives to add more storage.
    Anything from LaCie, G-Tech or WiebeTech would serve your needs fine.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Milton Hockman
    September 28, 2006 at 2:28 pm
    the reason i asked is because Avid Xpress pro will not work off of an external drive. it has to be internal because of speed limitations or something.
    never found taht to be a problem in Final Cut, but wanted to make sure.
    Motion Graphics Artist and Non-Linear Editor
    Software expertise include: After Effects, Avid Xpress Pro, Final Cut Pro, Dvd Studio Pro, Photoshop, and more.
