Activity Forums VEGAS Pro What settings for very long DVD with VHS quality
  • What settings for very long DVD with VHS quality
    Posted by Paul Gregory on April 24, 2007 at 1:15 am
    I currently have a very long project that will run almost 4 hours & will be put onto a dual layer DVD. The quality of the content is very good but the content is taken from old VHS tapes & isn’t very good.
    Since the originals quality is so poor I was thinking about making the DVD using setting for less than full frame PAL DVD of 720×576.
    I was thinking along the lines of 352×288 & using the largest bit rate possible for that size frame. Is this a crazy idea or not? Any suggestions will be much appreciated.
    Thanks in advance
    Laszlo Kovacs replied 19 years, 4 months ago 2 Members · 3 Replies
  • Laszlo Kovacs
    April 24, 2007 at 6:00 am
    I’m working almost dayly with old vhs tapes.
    Sure, if you capture something from such a tape,
    it does not have a real resoulution of 720*576, BUT
    it’s surely better than 352*288.
    At least you can see the difference, the material
    kept in 720*576 is much better seen on a TV, than
    another reduced to 352*288.
    I’d recommend to keep it highres.
    Don’t choose bitrate under 5Mbps, or you’ll see
    compression artifacts.
    By(t)e
    K.L.
  • Paul Gregory
    April 25, 2007 at 1:43 am
    I guess that my thinking was faulty. I had supposed that if put the same amount of data into a smaller frame then the data would not need to be spread out as thinly. Apparently I was wrong.
    It would have also been nice to been able to sharpen the video but I know that the sharpen tool often doesn’t produce acceptable results.
    Thanks in advance
  • Laszlo Kovacs
    April 25, 2007 at 6:06 am
    [The Old Fart] “I know that the sharpen tool often doesn’t produce acceptable results.”
    Don’t be afraid of sharpen. Just try it.
    It can subjectively enhance (a bit) a blurred image.
    Consider that lost information (image details)
    cannot be reproduced (as seen in high-tech tv series such CSI:
    they can get a high-detailed image from 4 pixels using a sharpen
    tool – that’s what we can not do ;D )
    When you apply sharpen, first make sure your preview window is
    720*576, preview is set to best.
    Look for a frame, that does not have too much movement, because
    sharpen also enhances edges that are cused by movement/interlacing.
    Set up the sharpen tool so.
    Because of the interlace issue in preview,
    render a few seconds of your video to see how it REALLY looks.
    Modify sharpen value if necessary.
    I hope i could help.
    By(t)e
    K.L.
