Activity Forums Boris FX Particle Illusion What setting would delay particle creation?
  • What setting would delay particle creation?
    Posted by Lance1 on March 12, 2006 at 7:22 pm
    I’m trying to make a magic emitter and I started with a black smoke emitter. I’m trying to add small stars to it but having difficulty because the other particles are strongly connected to the emitter parameters (so for example, I had to change the tint to get my stars white but now the smoke is not nearly as dark). Anyway, when I change the life setting of the small star particle it delays the creation of the stars as well as the life of the stars. What other setting is making the creation delayed? Life variation is only 3, but this should not delay creation, yes?
    Lance1 replied 20 years, 5 months ago 2 Members · 2 Replies
  • Elvis Deane
    March 12, 2006 at 11:35 pm
    Just a guess here, but the delay might be caused by the Transparency gradient. If a particle type’s Transparency Gradient starts out black and then fades in to white, and you increase its Life, it will take longer to fade into view. So if you move the second point of the gradient closer to the start, it might speed up how fast they appear.
    To darken the smoke again, you’ll have to do it in the Color gradient, since Tint affects the entire emitter.
    Elvis Deane!
    The Apprentice Magician’s Guide to particleIllusion
    The particleIllusion FAQ
  • Lance1
    March 13, 2006 at 12:25 am
    Wow! Good guess! You were exactly correct! Thanks!
