Activity › Forums › Panasonic Cameras › What SDI card for direct Varicam capture?
  • What SDI card for direct Varicam capture?
    Posted by Freeman on February 16, 2006 at 4:17 pm
    I have an upcoming project where I am considering using the Varicam but I am a bit confused…
    What I want to do is film to tape (with slow motion content!)->
    capture to disk by playing the tape from camera (uncompressed SD, not HD, if possible) ->
    edit ->
    rent a BETA-SP deck and output to tape
    Can this be done using a BlackMagic card and Premiere? I am worried about the slomo part, people seem to be having problems with this.
    Does anyone know what card I should get? I only need the uncompressed SD data, not the HD (I would prefer not having to update to faster and bigger SCSI-disks for the HD data).
    Help appreciated!
    Thank you,
    Karl
    Gary Adcock replied 20 years, 7 months ago 3 Members · 5 Replies
  • Shane Ross
    February 16, 2006 at 10:15 pm
    [Freeman] “What I want to do is film to tape (with slow motion content!”
    Well then why aren’t you shooting film? I don’t understand this statement.
    [Freeman] “capture to disk by playing the tape from camera (uncompressed SD, not HD, if possi”
    The Varicam is an HD camera, but with a capture card you can get SD. But I am very confused by this post. If you want film…shoot film. If you want SD, shoot SD. Get a DVCPRO 50 camera and use that to shoot. Capture SD…edit SD, output SD.
    Shane
    Alokut Productions
    http://www.lfhd.net
  • Freeman
    February 17, 2006 at 8:09 am
    To clarify my post: Is there a card that can downconvert the VariCam HD-SDI signal realtime to disk, without having problems with the slomo content?
    The reason I want to use the Varicam is that it will be cheaper than shooting film, we are as always on a budget. Also I will be shooting with an unexperienced crew and need to know what’s on tape all the time, can’t afford to find out problems later.
    I have considered using the setup you are talking about but I need to shoot slowmotion and doing that in post, to 60fps, won’t look nearly as good. Also I think I will have a better quality picture to start with from the VariCam.
    Karl
  • Shane Ross
    February 17, 2006 at 9:24 am
    I cannot say as to the workflow for shooting…I will leave that up to the fine Varicam operators on this forum. I just wanted to get some clarification.
    But as for the slo-mo…doing it in post looks GOOD. If you use the FRAME RATE CONVERTER that you can download from the Panasonic site, you can take 60P material and slow it to 23.98 and it looks amazing. And I think you can ONLY do the slowing of footage in post.
    But I’ll let the others supply better answers.
    Shane
    Alokut Productions
    http://www.lfhd.net
  • Freeman
    February 17, 2006 at 10:31 am
    Right, what I meant was that the footage from the DVCPRO 50 camera you suggested won’t look good if you slow it down in post. A reason for using the VariCam, it was made to do it so that’s going to look good…
    From what I understand the Frame Rate Converter was only released for Final Cut however the BlackMagic card seems able to do it without plugins, according to pressrelease:
    “VariCam footage recorded at 59.94 or 60fps can be captured and played back by DeckLink HD series cards at a slower frame rate, such as 24fps, presenting a slow motion playback effect on screen.”
    Which is nice only my question remains, can I input HD-SDI and convert and capture in realtime to uncompressed SD, keeping the slomo footage slowed down? Otherwise I’ll have to update my hardware to fast SCSI disks instead of SATA2 RAID, capture and then convert to uncompressed SD. A timeconsuming and costly hassle that it would be nice to avoid…
    Thank you for your replies, I have sent this question on to BlackMagic, I’ll post the response here…
    /Karl
  • Gary Adcock
    February 17, 2006 at 3:55 pm
    [Freeman] ” can I input HD-SDI and convert and capture in realtime to uncompressed SD, keeping the slomo footage slowed down? “
    Not with the decklink cards. BMD does down conversion via software so it is not real time.
    The AJA’s Kona Boards do not have any issues with the variable frame rate capture in any codec and since they
    use a hardware based Downconversion there is no delay or post processing needed. Additionally in the E-E modes on the cards this can be done with out opening FCP.
    Gary Adcock
    Studio37
    HD and Film Consultation
    Chicago, IL USA
