Activity › Forums › Lighting Design › What lights are best for photomontage captures?
  • What lights are best for photomontage captures?
    Posted by Jerome Robbins on February 3, 2006 at 6:13 am
    I have been dong photomontages for several years using two 60 watt incadescent bulbs directed down from a stand on to the photos and using a Sony PD100 mounted on the stand to capture the images with zooms etc. Lately I have noticed a tendency toward a red hue on many of the face shots and I have to color correct in my MX-50 mixer or later in my NLE system (Media 100).
    I am wodering if I switched to another light source if the problem with red would be lessened or eliminated,
    Any comments would be appreciated,
    thanks, Jerome
    jerome
    Frank Otto replied 20 years, 7 months ago 3 Members · 4 Replies
  • Keith Dobie
    February 3, 2006 at 5:16 pm
    Maybe I’m missing something but… isn’t it easier to scan the images so you can do nice motion effects inside your NLE? Or if you can’t scan them, use a digital camera?
    Keith
  • Frank Otto
    February 3, 2006 at 5:25 pm
    First, try replacing the lamps. Tungsten filliments tend to turn red as they age.
    Second, look into a more specific spectral lamp – there are quartz lamps made for photowork that are a true 3200k vs. a household lamp rated at 2700k. You can also use a Phillips 60w. Cool Halogena lamp rated at a constant 2900k – those are availible at places like Home Depot.
    Conversely, you could also use a fluorescent lamp rated for flickerfree digital use-check out photo supply stores or on-line. You’ll have to re-balance the camera for color temp, then again, you really should do that when you re-lamp anyway.
    Cheers,
    Frank Otto
  • Jerome Robbins
    February 7, 2006 at 6:27 am
    Thanks Frank,
    I went to HomeDepot and bought the Phillips Halogena 50 watt indoor/outdoor flood lights with the long neck. they are really bright. I had to set the shutter at 250 to deal with that. They seem to be too much of a spot light, even though they are a flood. When I put an 8X10 under the set up the light is really focused instead of spreading. I think I will take them back and try something else.
    Jerome
    jerome
  • Frank Otto
    February 7, 2006 at 4:51 pm
    Thanks for the info re: Halogena lamps – I wasn’t aware they spotted that much since the last globe I used of the type was a general purpose flood and had a relatively omnidirectional output.
    You might check with a photo store in your area for specific copystand photolamps- additionally you can diffuse and, if applicable to your rig, back off the lamps to lower the output.
    Cheers,
    Frank Otto
