Activity › Forums › DSLR Video › what lens mount should i get for rebel t3i?
  • Mike Smith
    March 5, 2013 at 9:50 am
    Both of those are lens adaptors – they are designed to fit onto the front of another lens. Direct body mounting is not going to be possible.
  • Steve Crow
    March 5, 2013 at 2:49 pm
    Is it too late to return those screw on lenses? You would have been sooo better of by purchasing the Canon 50mm 1.8 for $99-$120
    https://www.google.com/shopping/product/9079362058149002410?q=Canon+50mm+1.8&oq=Canon+50mm+1.8&aqs=chrome.0.57j0l3j62.1535j0&sourceid=chrome&ie=UTF-8&sa=X&ei=twU2UaaWF-K9ygHiuYBg&ved=0CNUBEMMf
    Steve Crow
    Crow Digital Media
    http://www.CrowDigitalMedia.com
  • Charles Meadows
    March 5, 2013 at 4:37 pm
    If you’re going to be using the lenses for video I’d suggest you get some of the Nikon lenses with manual apeture, just get an EOS to Nikon adapter, Another option would be to get the Rokinon cine lenses with EOS fitting, again these have manual apeture and I’ve heard some good things about them and they are pretty well priced.
    “There’s no point in filming if you don’t have fun”
    Charles Meadows
    Creative Director
    Incubate Productions South Africa
    http://www.incubatevideo.co.za
  • No Mercy
    March 5, 2013 at 4:50 pm
    That’s actually the next lens I plan to purchase. A friend has it and it’s great in low light
  • No Mercy
    March 5, 2013 at 4:55 pm
    Lighting is really my only issue. If those will help in low light situations then I’ll check them out. Thanks
  • Jordan Westhoff
    April 9, 2013 at 3:17 pm
    You do realize that these aren’t actually lenses, they are bolt on modifiers for lenses you currently have – ie. the glass you bought doesn’t really have any integrated optics.
    If possible, I’d return these and maybe get a Canon 50mm like was also mentioned, or a similar Tamron. You want the highest quality you can from a single lens that will cover your bases, both close up and farther away. I’m assuming you’re on a tight budget, but if you are not, start looking at some Zeiss or Cooke glass, they will make pretty pretty images for your Ti.
    Hope this helps!
    -Jordan Westhoff
    Rochester Institute of Technology
    BS Digital Cinema/Motion Picture Science 2015
