What is the right way to crop and to pan?
Hello!
I try to use Adobe Premiere Pro 2017 for making pictures slide show.
As picture resolution usually is much more than FullHD, I make cropping and pan by using motion effect (position and scaling).
There are two things that I can’t understand:1. If I made scaling from 10% to 50% and set linear option for keyframe than I get non-linear motion. It is slowing down to the end. Obviously it happen because I change scale in percent. Changing from 10% to 20% and from 20% to 30% takes the same time, but real size in pixels changes not the same. How can I do linear scaling?
2. When I’m changing position of the pictures in the frame I can’t get full control for composition because I don’t see anything beyond the frame borders (in Program Monitor window). It looks strange, because in other Adobe products (Photoshop, Lightroom) cropping frame shows over the pictures and every moment you can see what objects are into the frame and what are not. I think maybe I do something wrong? What is the right way to crop and to pan?
PS: Sorry for newbie question
