Activity Forums Avid Media Composer what is the keyboard shortcut to zoom in on edit?
  • Carl Amoscato
    September 22, 2005 at 3:02 pm
    You’re looking for the “Focus” command. On Adrenaline 2.1.6, it’s the “H” key. It’s also at the bottom left of the timeline, and it looks like two circles with a dot in the middle. If you’re on a different system, it might be in a different place.
    You could also use the CTRL+[ and CTRL+] keys to zoom in and out of the timeline. Again, these might be different depending on your system.
    good luck,
    Carl
  • Stephen Hockman
    September 22, 2005 at 6:02 pm
    i figured it out. I hit ctrl and M, then drag around the edit point and it zooms in there.
