What is the fastest way to create de-interlaced MPEG2 files from ProRes files with 3:2 pulldown
Hello,
I’m a bit of a novice, so I appreciate in any help I can get in advance. I’m looking for the quickest way to create de-interlaced MPEG2 files from Apple ProRes 422 files with 3:2 pulldown.
The ProRes file specs are: Apple ProRes 422 (HQ), 720 × 480, 4X3 aspect ratio, 29.97 fps, 63.48 Mbps. The file was originally shot on film and has a 3:2 pulldown. What I need is a MPEG2 transport stream file that has the 3:2 pulldown removed. It can be progressive and either a 29.97 or 23.976 frame rate.
I have Compressor, Final Cut and Cinema Tools. I’ve tried creating the files in Compressor with reverse telecine, but the final result makes the files look like every frame has lines/interlacing. I’ve tried altering the settings in frame controls and I’ve taken out the reverse telecine option with deinterlace option on the filters tab but that’s not working either. Can someone point me in the right direction on what I’m missing?
