Activity › Forums › Adobe Premiere Pro › what is the difference between subclip and master clip???
Posted by Gregory on November 4, 2006 at 8:51 pmthanks
Steven L. gotz replied 19 years, 10 months ago 2 Members · 1 Reply -
1 Reply
Steven L. gotz
November 4, 2006 at 9:42 pmA subclip is a clip that refers to the master clip, but with different in and out points. When you use a subclip in a project, you have a section of the master clip that can be uniquely named. Also, when you use Project Manager to trim the project, the subclips are turned into master clips so that you can avoid having to use the master clip from that point on.
Steven
https://www.stevengotz.com
