Activity › Forums › Adobe After Effects › What is the best way to trace a low quality video but not have a pixelated result?
  • What is the best way to trace a low quality video but not have a pixelated result?
    Posted by Daniel Haskett on June 18, 2006 at 6:43 pm
    Hi there
    Basically Ive got a low quality video of some birds flying that I want to trace, but at the moment when I do the end result is pixelated. I am using the mask tool to create the animation and im sure there is a better way to do this. Ive basically copied the mask shape keyframes onto a black solid but then I have to blow the black solid up to about 500% to get the bird the right size in a PAL DV composition. I am using continuously rasterize function but is there a better way of doing this so I dont have to increase the size so much…….or is this method ok?
    cheers
    dan
    Filip Vandueren replied 20 years, 3 months ago 2 Members · 1 Reply
  • Filip Vandueren
    June 18, 2006 at 11:50 pm
    copy the keyframes to your small solid,
    then resize the solid using the Solid settings (not scale)
    the mask-shape and it’s keyframes will scale with it:
    hurray ! 😉
