What is the best way to lay out color-coded Excel data in InDesign?
I’ve been away from layout for some time. I now need to lay out color-coded Excel data (3 columns, 200 rows) in InDesign 5.5. The data will need to be in alpha order and each row will be color coded, with a color key at the top of the page. What is the best way to lay this out? Should I use the table tool and create a new style for each color that I need to use?
Thanks for your help.
