Activity Forums VEGAS Pro What is the best way of prepairing proxy files for Vegas?
  • What is the best way of prepairing proxy files for Vegas?
    Posted by Leaning Less on February 14, 2015 at 1:11 am
    Usually i convert video in MPEG2 with low resolution and high bitrate and keeping the original file name. Is it advisable instead of it to use editing formats Apple ProRes or Avid DNxHD?
    John Rofrano replied 11 years, 6 months ago 3 Members · 2 Replies
  • Norman Black
    February 14, 2015 at 3:34 am
    Best varies in the eye of the beholder.
    The easiest way would be to use the Vegas smart proxy feature.
    If you want more control then using the proxy features of the Vegasaur or VASST Ultimate S utilities are pretty easy to use.
  • John Rofrano
    February 14, 2015 at 1:16 pm
    [Norman Black] “VASST Ultimate S utilities are pretty easy to use.”
    We (VASST) also have a proxy generator/swapping plug-in called GearShift that can do this. Check to be sure that it supports the video formats that you are using.
    It will render the proxies and then swap between proxy and original media any time you want.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
