Activity Forums Adobe After Effects What is the best way of exporting audio so it doesnt crackle?
  • What is the best way of exporting audio so it doesnt crackle?
    Posted by Daniel Haskett on May 31, 2005 at 6:26 pm
    Hi there
    Basically I have exported some audio from after effects as a 48khz 16 bit stereo wav file but it seems to crackle when the file gets louder. Admittdely in AE i have put the audio levels up to around 20db + in places but it sounds fine in after effects, why does it suddenly crackle when rendered out? Is there anyway of solving this or am i a bit screwed?
    Dan
    Aharon Rabinowitz replied 21 years, 3 months ago 3 Members · 2 Replies
  • Jayse
    May 31, 2005 at 7:03 pm
    I’ve had this problem if I’m sourcing an MP3 file and then rendering out –
    The guys at adobe told me a work around long ago – but I’ve just kept everything in my workflow as wav files and the problem has not returned.
    I don’t know what your source file is – but maybe that helps?
    cheers,
    // jayse
  • Aharon Rabinowitz
    May 31, 2005 at 10:59 pm
    MP3’s often cause that to happen. If you can avoid using an MP3 and try bringing in an uncompressed WAV that would work. I think you can even convert an MP3 into a wav externally, and it will be fine. It’s just that AE hates MP3’s.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
