Activity › Forums › Apple Final Cut Pro Legacy › what is the best option for timelapse capture in FCP
  • what is the best option for timelapse capture in FCP
    Posted by Miriam on November 3, 2006 at 3:36 pm
    I am searching for a plug in or function of Final Cut Pro that will allow timelapse capture over a number of days. I used to be able to do this in Adobe Premiere using their stop motion capture feature. Does FCP have such a feature? I am looking at BTV pro as it was mention in another thread from 2005. But that software was last updated in 2002 and I wonder how well it will work with current versions of FCP.
    Thanks for your help.
    Chris Poisson replied 19 years, 11 months ago 3 Members · 4 Replies
  • Jeff Carpenter
    November 3, 2006 at 3:50 pm
    I know iMovie has a feature that does this. It works with any firewire camera.
    When you switch to the camera input there’s a selection for time lapse capture. You can work in DV or HDV and then export it as a quicktime movie and import that into Final Cut.
  • Chris Poisson
    November 3, 2006 at 6:15 pm
    Miriam,
    For time-lapse capture I use BTV Pro, which is an all-around great capture tool. Bensoftware.com I think…
  • Miriam
    November 3, 2006 at 6:34 pm
    Hey,
    I downloaded the 15 day trial of BTV pro and it’s great. Simple and exactly what I was looking for. I am using the GL1 but capturing in 24p. Very cool. I am also going to try some HD capture to try and match the HD camera that we will be shooting the rest of the video with. We’ll see how that goes. I like how BTV pro lets you blend/merge a series of frames for each captured frame.
    Miriam
  • Chris Poisson
    November 4, 2006 at 5:09 pm
    Hey Miriam,
    Yes, it’s fantastic, the timelapse feature is VERY adjustable, so depending on the length of your original and the desired result, you may want to run off a few short tests before you go through the whole tape.
    Have fun!
    Also note that there are a bunch of settings for capture results, very comprehensive tool.
