Activity Forums Apple Final Cut Pro Legacy What is the best Full Rez/Uncompressed FCP export setting to use?
  • What is the best Full Rez/Uncompressed FCP export setting to use?
    Posted by Adam Davis on July 13, 2009 at 10:06 pm
    Hey guys,
    I am trying to figure out the best quicktime settings to use to get a Full Rez quicktime that will ultimately be output to DVCPro50 via Avid. I typically like using the Quicktime Movie option (self-contained) under File-Export option menu, but will Avid Media Composer be able to recognize and work with this file type?
    Also, this is a SD project that was shot on mini DV.
    Let me know if you need anymore info or have any suggestions.
    Thanks!!!
    John Fishback
    replied 17 years, 1 month ago
    4 Members · 4 Replies
  • David Roth weiss
    July 13, 2009 at 10:31 pm
    What codec are you editing?
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Bill Dewald
    July 13, 2009 at 10:44 pm
    Animation codec tends to be a favorite for sharing with Avid.
  • Adam Davis
    July 13, 2009 at 10:45 pm
    DV NTSC
  • John Fishback
    July 14, 2009 at 3:27 pm
    If you search the Cow you’ll find links to Avid codecs that when installed on your Mac will allow you to export files from FCP that Avid can use.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
