Activity Forums Boris FX Particle Illusion What is the best export format please before either After Effects, Sorenson Squeeze or Flash Video encoder?
  • What is the best export format please before either After Effects, Sorenson Squeeze or Flash Video encoder?
    Posted by Grant Barker on November 30, 2005 at 2:51 am
    So I would use maybe Sorenson Squeeze or the latest Flash Video Encoder to make an FLV, but I would like to make sure I am exporting with the best options for my projects.
    Thanks for the headsup.
    Grant
    https://www.grantbarker.com
    Grant Barker replied 20 years, 9 months ago 2 Members · 2 Replies
  • Alan Lorence
    November 30, 2005 at 1:04 pm
    The best format to render in pIllusion if you plan on bringing it into another application for further processing (such as After Effects) is to save in a lossless format. Neither Sorenson nor Flash Video is lossless (I believe). You’re better using the Animation QuickTime codec, or the Hhuuf UV codec, or saving as a TGA or PNG sequence.
    Alan.
    wondertouch
  • Grant Barker
    November 30, 2005 at 2:38 pm
    Thanks Alan.
    I’ll have a play around.
    Grant.
