Activity Forums Apple Final Cut Pro Legacy What is the best codec in camstudio to use when working in Final Cut
  • What is the best codec in camstudio to use when working in Final Cut
    Posted by Wesley Summers on September 25, 2009 at 7:11 pm
    Hello I am editing some how to videos that are 2-3 hrs long and captured using camstudio on a pc. Currently it is being captured using a divx codec and the files are .avi. They look good, but when I bring the files in to work on in fcp it takes an ungodly amount of time to render. I found a codec called Ensharpen that is supposed to capture in a quicktime format, I tried downloading a trail but for whatever reason it isn\’t showing up in the codec video options menu. I was wondering if anyone else has had experience working with screen captured files using camstudio and what codec or setting you would recommend.
    OR also thought of trying a scan converter to svideo or RCA, and then record it with a camera.
    Any help is greatly appreciated, b/c at this rate I might be through rendering by Christmas
    -Wes
    Rafael Amador replied 16 years, 7 months ago 2 Members · 4 Replies
  • Rafael Amador
    September 26, 2009 at 9:38 am
    Hi Wesley,
    I have never worked with that kind of stuff, but I think that capturing to any QT codec should be better.
    I think that to play the “Ensharper” codec you need a reader.
    Rafael
    http://www.nagavideo.com
  • Rafael Amador
    September 26, 2009 at 9:42 am
    Hi Wesley,
    Rafael
  • Wesley Summers
    September 26, 2009 at 1:37 pm
    Isn’t the “reader” camstudio or is a reader a seperate program of some kind?
    Wes
  • Rafael Amador
    September 27, 2009 at 3:13 am
    Hi Wesley,
    You can download the “Free Decoder” from this page:
    https://www.techsmith.com/codecs/ensharpen/
    Rafael
