Activity › Forums › Adobe Illustrator › What is happening here and how can I fix it?
  • What is happening here and how can I fix it?
    Posted by Tim Boknecht on July 11, 2014 at 4:59 pm
    I’ve created a logo with a custom “C” character and turned the entire logo into a single compound path.
    It looks like this:
    Trouble is, when I apply a graphic style to the compound path, the C gets all goofy on me.
    It looks like this:
    It doesn’t seem to matter what graphic style I apply. I’ve tried several and get the same result each time. I’ve isolated the C and made sure there were no stray points. I’ve run a simplify on it. Still get this goofy result.
    Can anyone explain to me what’s going on here and how I can fix it?
    Here’s what the path looks like:
    Tim Boknecht
    Media Producer
    Bravo Productions
    Vincent Rosati replied 12 years, 2 months ago 2 Members · 1 Reply
  • Vincent Rosati
    July 11, 2014 at 8:59 pm
    Hey Tim – I’m almost certain that the path in the C is cut, or is otherwise multiple paths.
    Maybe try resetting the path and fill of the compound object, than try Pathfinder / Unite. This could clean the C. Than retry the graphic style.
    If that doesn’t work, test all of the problem points in the C with the Direct Select to. You’d be looking for broken paths, by moving the points. If you do find a broken path you would use the Join command.
    Worst case scenario, upload the file and someone will fix it.
    Just some initial thoughts.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
