What is double PAL (or double NTSC) frame rate?
Posted by Nigel O’neill on November 8, 2012 at 10:19 amand when would you use it? It’s offered as a frame rate setting in Project properties
Andrea Kalli replied 10 years, 2 months ago 5 Members · 10 Replies -
John Rofrano
November 8, 2012 at 11:36 am[Nigel O'Neill] “and when would you use it? It’s offered as a frame rate setting in Project properties”
You would only use that if you bought a new camera that shoots 60p or 50p. Otherwise you would never touch it.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Thayalan Paramasawam
November 8, 2012 at 12:24 pmGood evenig sir,
Sir my camera also record at 50p…..so should i set 50pal at project setting.When rendering the project should i use 25pal or 50pal.
Thank you
Thayalan Paramasawam -
John Rofrano
November 8, 2012 at 1:33 pm[Thayalan Paramasawam] “Sir my camera also record at 50p…..so should i set 50pal at project setting.When rendering the project should i use 25pal or 50pal.”
Setting your project to double PAL will give you beter playback performance. Rendering is different. You should render for the device you are targeting for playback. If, for example, you are making PAL DVD’s then you should render to 25fps because PAL TV’s expect 25fps.
~jr
November 8, 2012 at 2:48 pmThank you sir for your information how about blu – rays
Thank you
John Rofrano
November 8, 2012 at 4:12 pm[Thayalan Paramasawam] “how about blu – rays”
Blu-ray supports 29.97fps, 25fps, & 23.976fps. That’s it.
~jr
November 9, 2012 at 6:58 amGood evening sir,
Thank you very much sir for your adivice.
Thayalan paramasawam
John Rofrano
November 9, 2012 at 11:51 am -
Andrea Kalli
July 9, 2016 at 12:55 amI recieved my first video from a client that had a frame rate of 59.94, and they wanted a few place cut out. I figured I would need to render in the same settings so as not to lose any quality. Unfortunately, I don’t have Double NTSC or Double PAL in the frame rate dropdown for anything. I wonder why that is? I have Sony Vegas Pro 13, but I did get the Edit version. Perhaps that’s why?
Wayne Waag
July 9, 2016 at 2:24 amWhat render codec are you trying to use? Some do not permit double frame rates. Try a Sony AVC Render Template. Then customize. Under frame rate, you should see both double NTSC and double PAL.
If all you are doing is simply cutting out a bit of the footage, you would probably do better with an editor such as VideoRedo or TMPGEnc’s MPEG Smart Renderer that supports smart-rendering. Vegas does not and will requite a complete re-render.
wwaag
Andrea Kalli
July 9, 2016 at 3:06 amI did end up finding it, based on what someone else posted, under the Sony AVC render templates (and then I found the Double NTSC in the frame rate dropdown box.) Saved it as a custom template so I know where it’s at from now on. Thanks for replying!!
Andrea
