[Binny Singh] “Is it safe to say that AJA is an external capture card that capture video uncompressed and thus produces a better quality?”
Not really. AJA is a company that produces a multitude of video centric devices from capture cards, external capture boxes, conversion boxes, adapters, etc…. http://www.aja.com has the full listing of product line.
The AJA Kona 3 is an internal video capture card that also features an optional external I/O box to connect all your audio / video sources. The capture card allows you to digitize footage as a much higher quality than straight Firewire. The entire Kona series also allows you to capture pretty much anything to anything. So you can capture DVCAM to 8bit Uncompressed SD or DV50 HD or upconvert it to 720p or 1080i HD. We use the Kona 3 to convert all HDV material to DVCPro HD during ingest. In the case of the Kona 3, you also get SD to HD Upconversion, HD to SD Downconversion, 720 to 1080 Cross Conversion and 1080 to 720 Cross Conversion all in realtime.
The IoHD is pretty much the same thing as the Kona 3, just in an external box. The only limitation is you cannot capture Uncompressed HD to the Io HD.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.
Read my Blog!
STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
