Activity Forums AJA Video Systems What i need to capture vintage Sony b/w on LHi card
  • What i need to capture vintage Sony b/w on LHi card
    Posted by Martijn Kempe on August 20, 2021 at 9:15 pm
    Hi, recently a 1969 Sony AVC-3250CE black and white-video camera fell into my lap, see photo.
    I would like to connect it to the AJA Kona LHi card in my MacPro 5,1, running Mojave.
    I tried a SDI-cable: nothing.
    A search on internet suggested I need a analog to digital converter.
    I’m new to all this, so could anybody point me in the right direction as to what kind of converter I would need for this B/W-signal.
    I don’t know if it is relevant info, but I’m in PAL-land.
    Thanks in advance!
    Martijn Kempe replied 5 years ago 2 Members · 2 Replies
  • Christopher Delaine
    August 25, 2021 at 3:41 pm
    If you are using a LHI card you need to find the composite input. This camera is not using an SDI signal even though it’s BC. This camera has a composite connection and you can use your LHI card without converters and such you just need the breakout cable for you LHI, find the composite input and configure the card correctly.
  • Martijn Kempe
    August 26, 2021 at 7:22 am
    That sounds great, Christopher! Thanks! I bought the Lhi 2nd hand, but I will go Breakout cable hunting now! Thanks again!
