Activity Forums VEGAS Pro What i am Doing wrong
  • What i am Doing wrong
    Posted by Accountclosed on January 18, 2006 at 7:39 am
    Every time i finish my project then render it whatever format i use to render it render well but when i just write it on CD and run on the DVD or VCD player it do not display as well as on Computer it just skip the corners from every Side
    inshort ” whatever format i use it just play perfect on computer but whenver i play it on any VCD or DVD player its just skiping corners cuting or do not display the full scene.” (i am using default project setting.) is there any project setting or what should i have to do.
    Thanks for your Time
    Regards
    ALI
    Accountclosed replied 20 years, 7 months ago 4 Members · 5 Replies
  • Yoyodyne
    January 18, 2006 at 7:46 am
    I’m betting what you are seeing is called overscan. Most televisions crop off about 5 to 10 percent of the outside of the image, your computer monitor does not have overscan so you see the whole thing.
    This is why Vegas has title safe areas, etc. Hope this helps
  • Jeremy Rochefort
    January 18, 2006 at 7:50 am
    Your default project setting should determine what your output format is going to be.
    From what I can gather from your post, you are using 16:9 footage (or project settings) and delivering on a 4:3 (or project settings) format. If this is the case, then your sides will cropped off.
    Some more info here would have helped in giving a more definitive asnwer – what resolution is your footage, what project setting are you using, what is your final delivery format you want??
    Cheers
    Jeremy
    MJ Productions
    MJ Productions
  • Accountclosed
    January 18, 2006 at 11:04 am
    thanks guys
    but now what should i have to do i mean what can i do to resolve this thing.
    i mean can you tell me what should i have to set my project setting and what should i have to render setting ?
    Thanks again for your time
    Regards
    ALI
  • Edward Troxel
    January 18, 2006 at 2:47 pm
    Do you have the “Stretch to fill frame” option checked on the Render As screen?
    Edward Troxel
    JETDV Scripts
  • Accountclosed
    January 18, 2006 at 5:24 pm
    Jeditdv no i do not select the “Stretch Video to fill output frame size (do not letter box)” { i found this option when Render window appear hope you’r talking about this }.
    can you tell me more about this or what we can do with the help of this option
    Waiting for your reply
    ALI
