Activity Forums Adobe Illustrator what have i done wrong?
  • what have i done wrong?
    Posted by Evrard Blom on May 14, 2006 at 3:06 am
    I was trying to create a 3D object in proAnimator (and in invigorator) from an AI file.
    ProAnimator says “there is no usable vector path in your file” and closes.
    How did i create the AI file? I simply opened Illustrator CS2, grabbed the pencil tool and drawn. I then saved as AI. And i clearly see the drawn object within Illustrator.
    Was there something alse i should do in AI? what does this error message mean? What is a “usable vector path” and how is it different from what iam seeing in Illustrtor right now?
    Thank you
    PS: I am totally new to illustrator.
    Wildfire replied 20 years, 4 months ago 3 Members · 3 Replies
  • Joe Hayden
    May 15, 2006 at 7:48 pm
    Did you try saving as an eps?
  • Evrard Blom
    May 16, 2006 at 10:25 pm
    Yes i did. But definitly unchecking the “use compression” helped fine.
    Thank you guys for being helpful 🙂
  • Wildfire
    May 22, 2006 at 11:58 am
    Try exporting as an eps, then exporting as an AI file rather than saving as one. You may need to back track and save/export as Illustrator 8 format.
