Activity › Forums › Apple Final Cut Pro Legacy › What happens when deleting old rendered fies?
  • What happens when deleting old rendered fies?
    Posted by Jonny Cates on August 27, 2014 at 7:09 pm
    I’m on a rush project. Got the message OUT OF MEMORY
    While editing an HD project that’s 10 minutes long, my render manager came up and said; OUT OF MEMORY – Check in the remove column to delete unwanted rendered files or free up disk space.
    What exactly will I lose by deleting my old, but needed project files? Will I still be able to refer to them in the future for my clients? Deleting doesn’t do anything to the timeline does it?
    Much appreciate any help
    Jonny Cates
    Rosie Walunas replied 12 years ago 5 Members · 4 Replies
  • Jerry Wise
    August 27, 2014 at 7:47 pm
    I’ve had that happen when I use pictures that are too large…like over 4000×4000.
    If you delete your render files you will have to re-render your time-line again.
    Also I’ve had out of memory when in “sequence settings” “video processing” my setting was at “render in high precision yuv”
    I change it to one of the two top settings and I’m good to go.
  • Daniel Waldron
    August 28, 2014 at 8:29 pm
    You can delete render files from old projects with no problem besides having to re-render them if you ever open the project again. It won’t delete any of your source footage or anything from your timeline.
  • Mark Suszko
    August 30, 2014 at 5:11 am
    Don’t forget to actually empty the trash when you do this, or you won’t see much change.
  • Rosie Walunas
    September 1, 2014 at 1:36 am
    I agree with all. Pictures are too big or they have an unfavored extension. Delete just the Render files and then re-render what you need.
    If that doesnt work… You could try dividing and conquering the seq until you find the trouble area then recut in the pesky clips or audio.
