Activity Forums Adobe Premiere Pro What happened to these in the sequence window of PP CC?
  • What happened to these in the sequence window of PP CC?
    Posted by Jim Collins on July 30, 2013 at 2:01 am
    Premier Pro CC doesn’t seem to have the sliders to manually adjust the beginning and ending of a sequence. See Photo.
    Is there a way to get them back or am I just out of luck. I always add a 2 sec blank timing before I have the video start. Without the sliders – the 2 sec blank space is ignored.
    Thanks in advance!
    Jim Collins
    Jim Collins replied 13 years, 1 month ago 2 Members · 2 Replies
  • David Gaudio
    July 30, 2013 at 2:43 am
    Go to the pull-down menu on the right side of your sequence, scroll down to where you see “work area bar” and click it…it should be there, but in the CC version, as I recall reading, it is now unchecked by default because so many people weren’t using it.
  • Jim Collins
    July 30, 2013 at 3:09 am
    David –
    Thanks – that did the trick!
    Jim Collins
