Activity › Forums › Maxon Cinema 4D › What happened to my shark?It can’t be scaled?Waiting for your answer
Posted by Overture Cheng on May 14, 2012 at 6:49 amHere the project
4136_shot004.c4d.zipOverture Cheng replied 14 years, 3 months ago 2 Members · 4 Replies -
Brian Jones
May 14, 2012 at 10:29 pmthe pose morph tag is killing the ability to scale (you either have to remove it or do the scale as part of a morph I think)
Overture Cheng
May 15, 2012 at 4:16 amThank U for your reply!
But how can I use the scale tool when I need to my shark opening it’s mouth?
I saw in the tutorial,the teacher use sth called the Morph tag.But I can’t find it in cinema4D tag… -
Brian Jones
May 17, 2012 at 4:46 amif the tutorial is old enough it could be before the PoseMorph tag which combines the older Morph tag and PoseMixer tags into one – check it out in the Help. It is possible to morph scale but depending on when you want the scale to happen it could be better to use some other method (like PLA perhaps)
Overture Cheng
May 17, 2012 at 4:55 amAll right,I think i should watch more basic tutorial.And now I’ve scaled it before I added the pose morph tag.
Thanks very much,Brian Jones.
