Activity › Forums › Adobe Premiere Pro › what format does premiere capture in?
Posted by Jeffrey on February 21, 2006 at 12:57 pmI was looking at getting premiere elements…when you capture footage from mini-dv, what format does it become? (i.e. avi, qt, etc)
thanks,
JeffJoesvideo replied 20 years, 6 months ago 3 Members · 4 Replies -
Tim Kurkoski
February 21, 2006 at 7:11 pmPremiere Elements captures as an AVI file. No changes are being applied to your captured video, though. The datat is stored in the AVI file using the DV codec, exactly the same way it is on the DV tape.
Tim Kurkoski
February 22, 2006 at 9:07 pmYes.
Encore cares less about the file format (it will accept AVI, QT, MPEG, or WMV) than it does about the specifications of the file. It must match the specifications for your Encore project, either NTSC or PAL (720×480 29.97fps or 720×576 25fps, respectively, though there are some minor exceptions).
Joesvideo
March 4, 2006 at 11:57 amI got Elements 2.0 along with pro because it allows me to capture mpeg 2’s off a DvD thats already in the burner. I then render it to avi and save. I close out of elements and open pro. Import the avi from elements and start editing. Really is a big time saver.
