Activity Forums Adobe Premiere Pro What format do I export out of Premiere Pro, in order to color grade a movie in Da Vinci Resolve?
  • What format do I export out of Premiere Pro, in order to color grade a movie in Da Vinci Resolve?
    Posted by Ryan Elder on July 28, 2019 at 8:33 am
    I want to color grade a finished project in Da Vinci, but I cannot figure out what format export out of Premiere Pro to do that, in which all the shots would be separate for Da Vinci. Does anyone know?
    Ryan Elder replied 7 years, 1 month ago 4 Members · 12 Replies
  • 12 Replies
  • Shane Ross
    July 28, 2019 at 4:54 pm
    You want to grade all of the original clips used in Premiere Pro, correct? Then what you do is export an XML, and import that into Resolve. And then in Resolve, either manually add the clips to the Media Pool first, and then the XML, or import the XML and have it bring in the media.
    Shane
    Little Frog Post
  • Ryan Elder
    July 28, 2019 at 5:30 pm
    Oh okay thanks, but I am using someone else’s sweet cause they have Da Vinci. When I move the XML over to their sweet, even if I have a back up copy of all the footage, Da Vinci still does not recognize where it is. So is there a way to get the clips into Da Vinci, without relying on the program having to look for where the back ups are?
  • Ryan Elder
    July 28, 2019 at 5:31 pm
    Like for example, if I give someone else an OMF container for audio, all the audio clips are in the container, and they do not have to be sought after in a different area of a hard drive. Is there a video version of an OMF container, where you have all the video clips in the container itself, instead of XML?
  • Greg Janza
    July 28, 2019 at 6:35 pm
    You’d be well served to do some youtube searching on Adobe to Resolve workflows. There are a ton of videos that explain the process in detail.
    https://www.linkedin.com/in/tmprods
    tallmanproductions.net
  • Ryan Elder
    July 28, 2019 at 9:24 pm
    Okay thanks, I found some tutorials on it and they say that Da Vinci does not accept XML and I need to export AAF out of Premiere. But I thought AAF was the same thing, and that you don’t get copies of the videos with it.
  • Greg Janza
    July 28, 2019 at 9:35 pm
    You’re using the wrong tutorials. Resolve accepts xml from Premiere and vice versa.
  • Shane Ross
    July 29, 2019 at 5:26 am
    Only AAF and OMF can contain media…XML cannot. And Resolve most certainly accepts XML, I online many many projects where I’m given an XML and media, from either FCX or Premiere, or AAF from Avid (linked to media, not embedded…which doesn’t work.
    You need to either bring the drive with the media to the suite, or copy all the media to another drive. And then, as I stated earlier, drag all the media into the MEDIA POOL, and then import the XML, and when it asks where the media is, point it to the bin in the pool where it exists.
    One BIG issue to note is that many editing apps do not add a needed bit of data to tapeless media…a unique reel number. And many tapeless media types are shot with cameras that repeat clip names, so you will have several with the same name, and timecodes that start over, so Resolve will have issues linking to the right clip.
    Shane
    Little Frog Post
  • Ryan Elder
    July 29, 2019 at 2:00 pm
    Okay thanks, but how do you fix the issue with Resolve not being able to link to the right clip?
  • Tero Ahlfors
    July 29, 2019 at 2:30 pm
    [ryan elder] “Okay thanks, but how do you fix the issue with Resolve not being able to link to the right clip?”
    That is called online editing/conforming and if it’s not linked automatically then you need to do it manually.
  • Ryan Elder
    July 29, 2019 at 5:33 pm
    Okay thanks, I just got back from attempting to do it on another sweet. I brought the harddrive with the footage on as well as the AAF. However, when trying to link the footage, the footage was grayed out and non-clickable. Does anyone know what the issue could be there?
