Activity Forums Avid Media Composer What firewire card should be used with HP nw9440 laptop?
  • What firewire card should be used with HP nw9440 laptop?
    Posted by Bbrammer on June 27, 2007 at 11:39 pm
    The HP has but one firewire port. Do I need to add a firewire card to the laptop? Should it have two firewire ports or just one?
    I’m thinking practical editing . . . would it be normal for drives to be on USB and the camera digitizing in via firewire. Or, do I need the extra firewire card so both drives and camera can be on firewire at the same time to facilitate digitizing?
    Bbrammer replied 19 years, 2 months ago 2 Members · 3 Replies
  • Joe Womble
    June 27, 2007 at 11:57 pm
    Avid does not support PCMCIA firewire devices, so I digitize FW sources via the jack and save off to USB drives for the nw9440. I have few if any problems with read/write throughput from DV footage. DVCPROHD will hiccup at full rez using USB, in my experience. If you drop your screen rez to yellow/green, it plays fine, even full screen.
    I have tried every FW800 PCMCIA card I can think of with no luck, BTW.
    I don’t know WHY HP had to get rid of the expresscard slot for this laptop! The previous flagship laptop, the nx9600, which I still have, has both PCMCIA and expresscard. My thought was to try and equip the nw9440 with the CalDigit expresscard adapter and get a SATA raid up and running. But CalDigit doesn’t offer a PCMCIA solution……
    Regards,
    Joe Womble
  • Bbrammer
    June 28, 2007 at 6:52 pm
    Thanks Joe . . .
    What of these listed on the Avid site?
    Qualified 1394 (FireWire) Cards for PC Notebooks include
    ADS PYRO 1394DV for Notebooks, part #API-601 or #API-602
    SIIG CardBus PC Card, part #NN-PCM012
    SIIG 1394 CardBus Dual, part #NN-PCM212
    IBM 1394 CardBus PC Card, part #19K5678
    The boot drive should be IDE, SCSI, or SATA 7200 RPM. Do not use internal SCSI as a boot device if you also plan on adding external SCSI drives (in which case use IDE or SATA).
  • Bbrammer
    June 28, 2007 at 6:54 pm
    Do these cards work with Avid Express Pro on an HP 9440 laptop?
