Activity › Forums › Apple Final Cut Pro Legacy › What FCP presets/easy setup to use for Canon 60d NTSC
  • What FCP presets/easy setup to use for Canon 60d NTSC
    Posted by Jeremy Smith on May 7, 2011 at 9:48 am
    I am using a Canon 60d in 30fps and was wondering what settings I should be using including
    sequence presets
    capture presets
    device control presets
    I want to create an NTSC video and DVD and it asks to convert the timeline to 50 fps for some reason to match the video and have no idea why. I can also shoot it in 60fps, but I am not sure if this helps me for NTSC format.
    Any help would be greatly appreciated. Thanks to anyone who can help me 🙂 Really!
    Jeremy Smith replied 15 years, 4 months ago 2 Members · 5 Replies
  • Cody Walters
    May 7, 2011 at 9:18 pm
    Hi Jeremy. If you haven’t done so, download the Canon plugin for FCP from Canons website. Once that is installed, you will bring your footage in as ProRes. When you create a new sequence and add your video clip, it should ask if you would like to match your setting. That is how it should work. If you are having problems with the frame rate changing on you, just click in your timeline and hit command 0 and match your sequence settings with your clip settings.
    Cody Walters
    JW Studio LLC
    Houston Video Production
    Houston Wedding Videos
    Final Cut Studio 3
    Adobe CS5 Master Suite
    Panasonic HVX-200
    Canon 7D
  • Jeremy Smith
    May 8, 2011 at 11:50 pm
    Thanks for your help people. I appreciate it! Chris thanks to you too, sorry am a total noooob here. Just wondering if this is what you are talking about?
    ce1120x.dmg.zip
    EOS MOVIE Plugin-E1 for Final Cut Pro Ver1.2
    If so I installed this, great. But then what do I need to do, Chris says L&T to Prores, um, sorry, what does that mean?
    Also do I use the Easy Setup?
    Thanks again, I really am thankful to you guys.
    Jeremy
    Here is what Chris said in a different post that I mistakenly put in a different forum.
    Shoot NTSC
    Shoot 60i
    Get the canon plugin.
    L&T to Prores.
    Export your edit.
    Compress the file for DVD.
    Chris Tompkins
    Video Atlanta LLC
  • Jeremy Smith
    May 9, 2011 at 1:26 am
    Ok, I did a few hours research and understand how to now Log and Transfer via the Canon plugin thanks mostly to this
    https://library.creativecow.net/articles/ross_shane/tapeless-workflow_fcp-7/video-tutorial
    however I have only previously used tape formats and would like to know what the Audio/Video settings are for a Canon 60d shot in 60fps for NTSC. Not sure what I should be putting in for the
    Sequence preset,
    capture preset,
    device control preset and
    Audio/video playback.
    This should then get me going, I hope.
    Once again, thanks for your help guys.
    Jeremy
  • Cody Walters
    May 9, 2011 at 1:14 pm
    The audio/video setup is going to allow you to set the preset of a new sequence. If you will be working with the 60D most of the time, set your sequence present to match that clips footage. I believe that would be 1920×1080, square pixels with a flavor of ProRes that you choose to import in L&T. Keep in mind after you have ingested your footage and add it to a timeline that Final Cut will ask if you would like to match your clip settings. Make sure to do this. And take a look what those settings are and make that your preset for sequences.
    Capture preset will be determined based the tape you are capturing. I’m not sure if you have external monitoring so I can’t give you a good recommendation for A/V and devise control.
    Hopefully this gets you up and running. Let us know if you need any more help.
    Cody Walters
    JW Studio LLC
    Final Cut Studio 3
    Panasonic HVX-200
    Canon 7D
  • Jeremy Smith
    May 13, 2011 at 4:42 am
    Fantastic, Thank you very very much for your help. If I am after slow motion shots, I am guessing it would be better to shoot in 60fps for everything I do and since it is going to DVD I wont need to worry about shooting in Full HD.
    Really the final and most important question is what do I put the System Preset on? Is it Apple ProRes 422 1280 x 720 60fps?
    Cheers guys, again I really appreciate your help!! Really!
