Activity Forums Avid Media Composer What encoding software do you use???
  • What encoding software do you use???
    Posted by Brent Hurlock on October 15, 2006 at 2:39 pm
    Greetings All. I have a Symphony system, 4.8 and do alot of encoding. (don’t we all). I’m either making WMV files for the web or DVD’s of the project of the day. The question I have for all of you is, what encoding software do you use? I use procoder 2.0, and I have to say its really really slow when working with QT files refrence or otherwise.
    In my expereince it runs about 25% realtime when encoding to MPEG2 or 30% realtime when encoding WMV’s. What are you guys using and are you getting better results with speed? Does a product like Squeeze do both MPEG and WMV’s? I need a better solution.
    Brent
    Brent Hurlock
    President, EditVision
    Michael Thomson replied 19 years, 11 months ago 3 Members · 2 Replies
  • Bouke Vahl
    October 15, 2006 at 8:44 pm
    Dunno your CPU, but in draft settings (for dailies) you should get about RT performance.
    For MpegII i use Cinemacraft. The cheapo version should fit your needs and is dirt cheap. It should give you RT at least. Also try TMPG encoder, also dirt cheap and does MpegII and WMV RT to faster than RT.
    If not, upgrade your CPU.
    hth
    Bouke
  • Michael Thomson
    October 17, 2006 at 4:29 pm
    Try Sorenson Squeeze. It ships with Adrenaline now-a-days too.
