Activity › Forums › Adobe After Effects › What does the triangle symbol in Info panel mean?
Posted by Sebastian Lee on December 19, 2012 at 2:12 pmSo, what does the triangle symbol in Info panel mean? Be aware that I’ve searched before posting.
Ryan Hill replied 13 years, 9 months ago 3 Members · 3 Replies -
John Cuevas
December 19, 2012 at 2:20 pmCan you post a screen grab, not seeing a triangle symbol, but the info panel does update depending on what you are doing.
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
Ryan Hill
December 21, 2012 at 4:10 pmI looked in my info panel. The only triangular thing I saw is an A for Alpha
Ryan Hill
December 21, 2012 at 4:14 pmWait, after I moved something a triangle appeared.
Position: 938.0, 538.0
[Triangle]: -22.0, -2.0That’s a delta symbol, it’s showing the change in position.
