Activity Forums Media 100 What could cause this?
  • What could cause this?
    Posted by Gerry Condez on August 23, 2011 at 3:24 pm
    Been using the same system for quite some time now and all of a sudden, cant play the video. Just like having some bad video frame. I would like to know what could have caused this. (image)
    I never had problems before and what could cause the CPU to slow down, Video is from AVCHD files. Please advise.
    Thanks – Gerry
    System,
    Apple Xserve – OS 10.5.8
    M100 – 1.6.1
    8 core/ 3.0
    Kona 3
    10gb RAM
    512mb video RAM
    Jaeson Koszarsky replied 15 years ago 3 Members · 3 Replies
  • Floh Peters
    August 23, 2011 at 3:25 pm
    Sounds like either too many effects, or too high data rate. What codec are you using?
  • Gerry Condez
    August 23, 2011 at 3:46 pm
    Hi Floh,
    Thanks, No effects at all just dissolves. I’m using ProRes 422 (HQ). Initially for the first time I tried using a short 6 sec moving background with 50 percent opacity to test on the titles. When if first showed up, I took the clip away and played the same clip and it worked. but after the 2.5 hour program was edited. This prompt was showing everywhere. Thanks
  • Jaeson Koszarsky
    August 23, 2011 at 8:26 pm
    A system reboot will often resolve many things.
    Avoid running too many other apps in the background. Check the Activity Monitor in Applications/Utilities for anything unusually taxing.
    Check your drives with Disk Utility.
    Make sure you codecs didn’t change on you and your media is where you want it.
    Jaeson
