Activity › Forums › Blackmagic Design › What converters for analog HD client monitor
  • What converters for analog HD client monitor
    Posted by Aaron Neitz on April 21, 2005 at 6:47 pm
    What HD-SDI converters are people using to break off a signal for a consumer HD client monitor (like a sony CRT)? about how much would one cost?
    Aaron Neitz replied 21 years, 5 months ago 2 Members · 2 Replies
  • Luke Maslen
    April 22, 2005 at 12:56 am
    Hi Charlie,
    Both the DeckLink HD Pro 4:2:2 and DeckLink HD Pro 4:4:4 cards are HD-SDI cards and also include component analog video monitoring. So you can capture and play back to the deck via HD-SDI and have inexpensive analog monitoring via the component outputs of the card. The DeckLink HD Pro 4:2:2 card is US$1495. The DeckLink HD Pro 4:4:4 card is US$1995.
    If you are looking for a standalone convertor, then one of the Multibridge units would be great and we hope to recommence shipping shortly.
    Regards,
    Luke Maslen
    Blackmagic Design
  • Aaron Neitz
    April 22, 2005 at 4:47 pm
    Thanks Luke. Because our edits bays are about 30 meters from the machine room, what we’ve found works best (for SD work) is a single SDI cable to the edit room which feeds the BVM, and then taking the SDI loop off the monitor into an AJA SDI-Component brick for the 32″ Wega in the back of the room… and at this point, we don’t have an extra 3 BNC runs on the bulkhead.
