Activity › Forums › VEGAS Pro › What conditions prevent photopshop *.psd file being dropped into vegas
  • What conditions prevent photopshop *.psd file being dropped into vegas
    Posted by Harry Putnam on January 24, 2011 at 3:03 am
    Running Vegas Pro 10 under win7 64 bit
    Are there some known conditions which prevent certain Photopshop format *.psd files from being dropped or imported into vegas?
    I have a curious situation where I’ve done some work in a tool called `Xara designer pro’, assembled 4 images into a simple collage, exported it to Photoshop format, opened it in photoshop and cropped it,saving back to the same name and format (*.psd).
    I’ve done several of these, and had no trouble loading them into vegas, but now one of the same set will not load.
    I redid it from scratch through all the steps listed above. The second effort failed in the same way. Vegas tells me, `None of the files dropped on vegas could be opened’.
    Looking at the problematic file and the one right before I see they are very similar in size and in dimensions and done with the same steps.
    If I save it out of Xara as *png instead of psd format, it loads with no problems.
    How can I determine what the problem is?
    Stephen Mann replied 15 years, 8 months ago 3 Members · 2 Replies
  • Mike Kujbida
    January 24, 2011 at 3:22 am
    The only times I’ve had issues with graphics files and Vegas is when they were saved in CMYK format.
    Changing it to RGB always solved my problems.
  • Stephen Mann
    January 24, 2011 at 5:24 am
    I’ve also had a problem when the psd file contains duplicate layer names.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
