what compression using MPEG Streamclip
so I downloaded mpeg stream clip since the Q&A sugeested that here..
Im importing it into FCP as quicktime.. default compression is apple motion JPGE A.. is that good .. which is the best ..thank you..oh and quality was at 50% why would I want 50% should it not be at 100 instead.?
