Activity Forums VEGAS Pro What codec should I use to render SonyVegas project to DavinceResolve?
  • What codec should I use to render SonyVegas project to DavinceResolve?
    Posted by Heerni Needik on May 10, 2015 at 3:28 pm
    Hello everyone!
    I have to get SonyVegas project to DavinciResolve for color correction. SonyVegas running on PC and Davinci running on Mac. I want to render as high quality video as possible and then use Davinci scene detection. What is the best format and codec for render? I need to best quality for color correction.
    Thank you!
    Heer
    Timothée Ferreol replied 11 years, 3 months ago 4 Members · 3 Replies
  • John Rofrano
    May 10, 2015 at 7:26 pm
    [Heer Need] “I want to render as high quality video as possible and then use Davinci scene detection. What is the best format and codec for render? I need to best quality for color correction.”
    I would use Avid DNxHD for all video transfers between PC and Mac. I have a tutorial on my web site on how to create the Vegas Pro template for it:
    Avid DNxHD Template for Vegas Pro
    You’ll also need to install the Avid DNxHD codec on the Mac. This should give you excellent results across the two systems.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Dave Osbun
    May 11, 2015 at 2:20 pm
    I always take my files into Resolve first, do my corrections, then I export for editing.
    I’m not sure if that’s how others do their workflow, but it’s easier for me if I do it this way.
    Dave
  • Timothée Ferreol
    May 27, 2015 at 8:58 am
    Dave, you color correct all your footage before exporting them to SVP ? Wow how long does it take you ? Plus won’t you be color correcting footage you will remove later in editing ?
    ___________________________________________
    If you want to check out my work =) : https://vimeo.com/timof
