Activity › Forums › Avid Media Composer › what codec for DVCAM into Avid using Squeeze?
  • what codec for DVCAM into Avid using Squeeze?
    Posted by Matthew Lovering on July 21, 2012 at 3:01 am
    Hi
    I posted this on the Cr. Cow sorenson forum but perhaps it’s really an avid question.
    I’ve been given 8 hours of PAL DVCAM footage already digitised off tape and I want to use Squeeze to convert the .mov quicktimes to AVID friendly format. I don’t want to link using AMA and transcode later in Avid. I’ve done this a few times for HD footage – it works well, is faster and lets me control which folders I put the footage in in the main AVID mxf folder, but for SD which codec setting is the most appropriate to use? Avid 1:1? Avid DV100? some other one?
    The finished projects will be going onto the web but I’ll keep everything interlaced in case someone wants to make a DVD later.
    I’m using Squeeze Pro 8.5 and Symphony 6 on a mac.
    thanks for any help 🙂
    cheers
    Matt
    Bouke Vahl replied 14 years, 2 months ago 2 Members · 1 Reply
  • Bouke Vahl
    July 21, 2012 at 10:02 am
    Avid has DV as native codec.
    So you could ama and consolidate, not transcode.
    This will be lighting fast, and no quality loss.
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pros
