Activity Forums Adobe Premiere Pro What causes AME to hang?
  • What causes AME to hang?
    Posted by Jim Bachalo on September 15, 2011 at 12:33 pm
    Hi
    Have a 6 minute project with lots of dynamic linking. Also using 5 or 6 adjustment layers for grading and CC in AE.
    If I turn off all the adjustment layers, and output using single pass CBR, no problem , I have a full render in about 2 hours.
    However, if I output as high quality using VBR-2pass, and turn ON all adjustment layers, AME only renders for about 5 hours of an estimated 14 hour total render…then nothing…it hangs.
    Just wondering what some of the possible causes for hanging are and what I should try next.
    As a last resort will render sections and then splice together but would like to avoid this.
    Local is the new global
    Max Frank replied 14 years, 7 months ago 2 Members · 1 Reply
  • Max Frank
    January 23, 2012 at 8:39 am
    Hi Jim,
    Did you ever get an answer for this, or find a solution. I’m having the exact same problem and it’s killing me!!!!!
    Tx.
    Wayne
