Activity Forums Adobe After Effects What can i use to control distance between bars to create a .mogrt bars chart?
  • What can i use to control distance between bars to create a .mogrt bars chart?
    Posted by sara de avila on May 10, 2021 at 3:12 pm
    Hey guys!
    I’m trying to create some charts in .mogrt, so that the editors at work can easily edit it directly in premiere. I took a look at some archives like this, to understand the parameters that can be editable, but i couldn’t unsdertand how to make a controller for the the distance between the bars, and how control the thikcness of all the bars at once. Does anyone have any idea of what i can do to create thise two controlers like in the video? “Distance between bars” and “bars thickness”? I saw that maybe i would need tu use expression, but i don´t know if i can use that as a parameter for .mograts. Thank you for the attencio!
    sara de avila replied 5 years, 3 months ago 2 Members · 3 Replies
  • John Cuevas
    May 11, 2021 at 7:58 pm
    Had some free time, so I made an 8 line bar chart that you can use in Premiere. Added a global height slider and a gap control. Also, there is a global color fill or if you want, you check the ‘Individual Fill Color’ checkbox and drill down into each bar and change the colors.
    Each bar also has it’s own X length slider and a checkbox to turn the layer off if you don’t need. it.
    Hope this helps.
  • John Cuevas
    May 11, 2021 at 8:49 pm
  • sara de avila
    May 12, 2021 at 12:45 am
    Wow! Thats is really amazing!
    Thank you so much, totally saved me, i really wasn’t expecting for that haha! It’s really great to have both, .mogrt and .ae projects, to understand better how it works. Thank you again! <3
