Activity Forums Apple Final Cut Pro Legacy WHAT BANDWIDTH SHOULD i GET WITH THIS SET UP?
  • WHAT BANDWIDTH SHOULD i GET WITH THIS SET UP?
    Posted by Lee on February 28, 2006 at 6:05 pm
    Hi Guys
    Heres what I got
    3 X FCP SYSTEMS KONA WITH XSAN AND FIBRE CHANNEL BASED
    XSERVE
    QLOGIC SWITCH,
    XSERVE RAID ( ONLY 1 TB 4 sata DRIVES)
    How many streams do you think I should be able to get with only 1TB
    Do I need to upgrade and fill the raid with drives ASAP?
    I have one machine capturing from digi beta and another machine editing and I’m dropping frames everywhere
    Is this my problem?
    Thanks for the help
    Paul
    Graeme Nattress replied 20 years, 7 months ago 3 Members · 4 Replies
  • Graeme Nattress
    February 28, 2006 at 11:13 pm
    You really need a fully populated Xserve RAID. Anything less is just not worth it for any kind of “speed” you also need other drives for a metadata volume for XSAN.
    Graeme
    http://www.nattress.com – Film Effects and Standards Conversion for FCP
  • Mark Raudonis
    March 1, 2006 at 4:32 am
    I agree with Graeme. More spindles equal more throughput. Fill out the spaces and your performance will increase.
    There’s also a fair amount of arcane settings when configuring your X-SAN. Did you have a qualified installer help you set it up?
    mark
  • Lee
    March 1, 2006 at 1:20 pm
    yes i had someone install it but im wondering what bandwidth do I get if I populate it
    can I use standard sata drives?
    apple are giving me a 6 week delivery time on delivery on extra drives!
    Paul
  • Graeme Nattress
    March 1, 2006 at 2:12 pm
    Who installed it? An XSR should never be sold with less than a FULL compliment of drives. What are you using for your metadata controller? Where and how are you storing the metadata?
    On a fully populated XSR you should be getting a conservative, reliable 300MB/s read and 200MB/s write when configured as two RAID5’s RAIDed 0, ie RAID50, direct connected.
    Graeme
