Activity Forums Adobe After Effects What Audio/Visual Sync Effect Is This?
  • What Audio/Visual Sync Effect Is This?
    Posted by Kevin Huang on February 19, 2014 at 2:51 am
    I need some help with identifying what the following AE technique is and how I could replicated it:
    https://www.youtube.com/watch?v=vhD_nbzKKys
    The effect that I am referring to is the audio and visual sync in which the image will have a “ghost plusing” effect when ever a certain frequency for the audio track is detected (normally a lower frequency/bass). If anyone could help me with this that would be great!
    Thanks in advance.
    Kevin Huang replied 12 years, 7 months ago 2 Members · 2 Replies
  • Todd Kopriva
    February 19, 2014 at 6:36 am
    There are resources here to get you started:
    https://helpx.adobe.com/after-effects/using/assorted-animation-tools.html#convert_audio_to_keyframes
    After Effects team blog
  • Kevin Huang
    February 25, 2014 at 8:30 am
    Thanks for the resource however I have a couple more questions.
    I’ve used Trapcode Sound Keys instead to produce the audio key frames and wish to add an adjustment layer like the one in the video. I think the video uses curves and scaling to produce the ghost pulsing effect but I’m not too sure on that.
    I’ve used Light Burst 2.5, is that the effect name?
