Activity Forums Maxon Cinema 4D What are these black dots in some frames? what setting I need to change to avoid
  • What are these black dots in some frames? what setting I need to change to avoid
    Posted by Andy Corleone on October 7, 2023 at 4:18 pm
    What are these black dots in some frames? what setting I need to change to avoid them?
    about 7 frames out of 240, Using Cinema 4D Phisical Render with Ambient Occlusion and GI on. When I Re-Render Usually doesn’t show again but not sure how to solve it in the future.
    Kouraib Abdmalek replied 2 years, 11 months ago 2 Members · 4 Replies
  • Kouraib Abdmalek
    October 8, 2023 at 8:45 am
    Hi Andy,
    you could try to change the primary method in GI to QMC and increase the FPS in the output to 60 like in the screenshots below, I think that will solve the problem
    hope that will help you
  • Kouraib Abdmalek
    October 8, 2023 at 10:11 am
    Also if you think that the lights getting hotter in your scene, try bringing the light intensity down or the samples up.
  • Andy Corleone
    October 8, 2023 at 12:52 pm
    thanks so much I will try and see, So do you think this is an over expoxed issue? cheers
  • Kouraib Abdmalek
    October 9, 2023 at 8:34 am
    You are welcome! I’m happy to help you, this an example from someone else who had the same problem and was solved by bringing the samples up.
