Activity Forums Adobe Premiere Pro What are the steps to creating a letterbox on 16×9 format?
  • Jeff Pulera
    December 15, 2008 at 9:43 pm
    Hi Chris,
    A little more info would be helpful – what is the source, destination (DVD?), project settings?
    If working with widescreen DV or HDV, then simply Export using a 16:9 DVD setting and the DVD player should recognize when using a 4:3 display and it will letterbox the footage on output.
    If you want actual 4:3 video with black bars, then edit the footage in a 4:3 project
    Jeff Pulera
    Safe Harbor
