Activity Forums Apple Final Cut Pro Legacy What are the restrictions on the 1st Chapter Marker in Final Cut Pro 5?
  • What are the restrictions on the 1st Chapter Marker in Final Cut Pro 5?
    Posted by Sebastian Knight on April 10, 2006 at 5:17 pm
    I know you can not place a Chapter Marker at the very beginning of a sequence, other that where can I place my 1st Chapter Marker?
    As always thanks in advance for reading and replying to my Post,
    Sebastian
    Sebastian Knight replied 20 years, 5 months ago 3 Members · 3 Replies
  • Jeremy Garchow
    April 10, 2006 at 5:19 pm
    Is this for use in DVD Studio Pro? If that’s the case, then DVDSP will put a marker in the beginning for you. If not, try putting a marker 10 frames in and then replace the default one with that in DVDSP.
  • Gary Hughes
    April 11, 2006 at 10:47 pm
    According to Final Cut Pro’s error messages, chapter markers must be at least 1 second apart from each other AND at least 1 second past the start of a timeline. If exporting chapter markers from FCP, it will not cause a problem, it will simply ignore them and not export them.
    Gary
  • Sebastian Knight
    April 12, 2006 at 1:03 am
    Thank you, this is exactly what I wanted to know.
    Sebastian
