Activity Forums VEGAS Pro What are the best video & audio properties settings for Sony Vegas Pro 10 & the best video & audio rendering settings for Youtube?
  • What are the best video & audio properties settings for Sony Vegas Pro 10 & the best video & audio rendering settings for Youtube?
    Posted by Sean Tujaka on May 3, 2011 at 4:47 pm
    ↓*Here are my current Sony Vegas Pro 10 Properties*↓
    File>Properties>Video:
    Template: HDV 720-30p (1280×720, 29.970 fps)
    Field order: None
    Pixel aspect ratio: 1,000 (Square)
    Output rotation 0° (Original)
    Frame rate: 29.970 (NTSC)
    Stereoscopic 3D mode: Off
    Pixel format: 8-bit
    Full-resolution rendering quality: Best
    Motion blur type: Gaussian
    Deinterlace method: Blend field
    [✔] Adjust source media to better match project or render settings
    File>Properties>Audio:
    Master bus mode: Stereo
    Number of stereo busses: 0
    Sample rate (Hz): 44,100
    Bit depth: 16
    Resample and stretch quality: Best
    And.
    ↓*Here are my current rendering settings*↓
    Template: 6 Mbps HD 720-30p Video
    Custom>Audio:
    [✔] Include audio
    Mode: CBR
    Format: Windows Media Audio 9.2
    Attributes: 192 kbps, 48 kHz, stereo (A/V) CBR
    Custom>Video:
    Mode: CBR
    Format: Windows Media Video 9
    Image size: High definition (1280×720)
    Frame rate (fps) 29,970 (NTSC)
    Seconds per keyframe: 5
    [✔] Override default compression buffer (seconds): 3
    Video smoothness: 100
    Custom>Bit rate:
    Target bit rate (bps): [✔] Internet/LAN 6 M
    Thank You (^_~)b
    Douglas Spotted eagle replied 15 years, 4 months ago 2 Members · 1 Reply
  • Douglas Spotted eagle
    May 3, 2011 at 5:21 pm
    looks as though your source is HDV 1280 x 720…
    Render to 10Mbps 1280 x720 mp4 if your content is high motion. Render to 6Mbps if it’s low motion.
    https://www.youtube.com/watch?v=7pP043Eg0zs
    lots of color/motion/movement…
    Youtube will take wmv, but wmv hoses the colors in the conversion.
    Douglas Spotted Eagle
    VASST
    Certified Sony Vegas Trainer
    Aerial Camera/Instructor
